Discuss Cutting stone, more power or better blade in the Australia Tiling Forum area at TilersForums.com.
Musivarius
Just to get some opinions on here;
I'm cutting a lot of marble into small pieces (10mm cubes) using a Vitrex 900 watt bridge saw and I try various blades on it. I cut for 3 - 4 hours at a time. I'm looking at a Belle BC350 which has 2.2hp.
My question is for faster cutting would I be better getting better getting better blades for the Vitrex or do I need more power? If I used the same blade on both would the cutting be noticeably faster on a more powerful machine or is it down to the blade? ATS have been very helpful but i'd be interested to what you guys have to say.
Concrete guy
Hello Lawrence,
I know I answered most of your questions when you posted elsewhere but just to add a little more I would consider the following in order of importance, this assumes there is a reasonable machine to start with.
1. Blade specifically for the material being cut.
2. More power
The perfect outcome being specific blade + more power. But the blade is where to start.
Concrete guy
Yes, that's the one. I must have used it for about 12 hours so far and it's still cutting as well as when I first put it on.
That's interesting thanks, we promote those for porcelain and hard tiles but they seem to perform well in natural stone.
If you find it starts to slow, then run it through something abrasive like a piece of sandstone, that should wear the metal bond and expose some new diamond.
a good blade can improve a cutter, a cutter is only as good as the blade in it imo.
That's exactly my thoughts, I've seen guys use cheap disposable blades that chip and struggle with even the soft stuff. They think that's just the way it is until they try a decent blade like I use
Reply to Cutting stone, more power or better blade in the Australia Tiling Forum area at TilersForums.com
Hello guys I’m looking for some advice I will be attempting to redecorate my living room which...
Can anybody recommend a cutter that will produce very good edge cuts on 10mm very hard porcelain...
9K
Hi guys, its my first post on there though have been gaining useful tips for a while so thanks...
Do any of you guys use a dremel for cutting tiles or mosaics? If so, can you recommend which...
Concrete guy
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
