Tiling Tool Suppliers
Discuss Cutting tiles with out using a wet cutter in the Tile Cutters (Manual & Wet Cutters) area at TilersForums.com.
gary b
hi guys
I've always used a wet cutter to cut my tiles where ever my dry rail cutter can't do. I've always done that as that is how I got shown. My question is is that the norm. Do you guys use wet cutters or do you use angle grinders ?? Which is really what my question is about. I've never used angle grinders but the more tillers I speak to, the more seem to use. I'm only asking is because work is a bit slow at the moment, so looking at site work to bring some money in, but the thought of lumping my wet cutter around isn't appealing, also it's not 110v, so I would have to probably get a new one.
Many thanks any advice is really appreciated
gary b
Okay thank you.
What do I actually need then to cut the tiles. I'm guessing you would need a black and decker work mate to cut the tiles or something like that to hold the tile when you cut it. Also would a cordless angle grinder be okay as I've got cordless drills where I can use the battery's on other tools.
Thanks again i no it's sounds simple and all that but I never got taught how to use a angle grinder
I only used to use a wet cutter when I did my private work. However on switching to site work a couple of years ago I now only use a cordless grinder. I have a dewalt grinder and drill with a 5AH battery for each . That pretty much does me for 2 days for most stuff on walls , if its floors I'd charge each day. What you have to remember is most of the stuff ur gonna cut with the grinder isn't going to be on show for the most part , no skirtings etc.
For angle cuts on wall tiles I scribe both lines , grind diagonally to the corner then snap out both sections , nice clean cuts for around windows.
As for soils on floors I now carve out shape with the grinder to create a 2/3mm groove , few lines in , snap out. Takes a couple of goes to get used to but still gets good site finish , need to roll your wrist as you go round the shape.
The only time I now break out the genny and sms 202 is for HA kitchens , bumpy whites are just better suited to it being so thin.
Diggy
Just to add to your other Q.
Get a Keter bench , Ive never looked back since buying one , saves my old body from bending down. As regards using it for cutting , place tile on the bench with bit to be cut hanging over edge , then place a bucket of water/adhesive/tools on it to hold it down if doing a circular cut out. For small angles its possible to just hold it after a bit of practice , not exactly H&S but hey ho. :0)
Oh and I use an Erbaur turbo blade , £7.99 from screwfix , cos I'm a tight wad :0)
Works fine for me though .
Diggy
Reply to Cutting tiles with out using a wet cutter in the Tile Cutters (Manual & Wet Cutters) area at TilersForums.com
Hi everyone, I'm not a regular tiler, just someone who is trying to fix up a few rooms around...
Currently using TX700N but obviously now too small for the 1200x600mm I'm increasingly being...
Popular Tile Cutter Threads
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
