Discuss cutting tiles without chipping them in the UK Tiling Forum area at TilersForums.com.
U
Unregistered
hi all, i am tiling our bathroom, al gone fine but when cutting tiles around the bathroom window have run into problems.
the tiles are 600*300 glazed porcelain.
i bought one of those electric tile cutting tables, when i cut the tiles it leaves a serated edge on the tile. would i get a better cut / finish if i bought a cutter such as a Big Clinker Tile Cutter 610mm.
the tiles are about 9mm thick.
thanks
paulyoung666
thanks
i bought the cheap ( £30 ) wet cutter from tops tile to cut my glazed porcelain and it was fine , you are not trying to force the cut are you ? , it might be part of the problem :thumbsdown:
Shawn Hickman
thanks
Here is a guide for you, that will definitely help:
<a href="7 Best Wet Tile Saw under $300: Top Picks and Reviews 2021 - https://toolsteller.com/best-wet-tile-saw-under-300/">Cutting tile guide without chipping</a>
Reply to cutting tiles without chipping them in the UK Tiling Forum area at TilersForums.com
There's a video on youtube of a guy templating for large format floor tiles, and I get the...
Hi, new to forum and first post, after some advice. Recently had the chamber of my fireplace...
Hello, I hope you can help. I'm get despondent cutting 9mm glazed porcelain tiles, 300 x 900mm...
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
