Cutting U Shape Bit From Tile
Retroelec
Thanks for the advice so far.
I have to cut a U shape piece that will slot around a stud wall at the end of the shower tray.
I have 600 x 300 porcelain tiles and this is the only one i need to cut a slot out of as all the rest have been done with the score and snap cutter.
I have tried one of those hand tile saws but would be there all year I have a angle grinder though would this do it?
They are 12mm thick and the cut doesn't need to be perfect as skirting or a wall tile will cover it.
If this way will cost me more in broken tiles than a electric saw do you have any cheap ones that you would recommend as I will only be needing it for this cut as hire of one is £40.00 for one day anyway?
Drill holes in the corners then use the angle grinder to cut up to and between the holes.
For a first timer with an angle grinder, personally wouldn’t recommend a continuous rim blade, you could trash it in 30 secs with porcelain and still not achieve your cut.
My choice would be a mesh type blade, they’re readily available now and relatively inexpensive and you will manage the cut, first timer or not.
This is excellent for the money from @Pro Tiler Tools
I’m on my second now.
PREMTOOL Turbo Fastline 115mm x 22.2mm Diamond Blade TUR115 | Buy Diamond Blades (Tiling) Online from Pro Tiler Tools - https://www.protilertools.co.uk/product/premtool-turbo-fastline-115mm-x-22-2mm-diamond-blade-tur115
Depending on width of your cut out, will depend on cut out method, but asPaul says above, you should really drill the corners first to help eliminate unwanted cracks appearing.
Then either follow your outline as Paul suggests, or if you’re unable to turn your blade perpendicular to the parallel cuts because of its narrow width, use your slide cutter to join the dots (drill holes) at the top of your cut out, but do not snap and run the blade up to this line every 10mm or so creating lots of parallel cuts.
Once done, typically you can just tap them out and then tidy the end line up with your blade.
@3_fall is this good for the angle grinder as well as the slide cutter ?
Any concerns over a thin blade in this case ? And is there a locally available blade suggestion ?
I think you should quote exactly the bit where you’ve found confusion.
I’m afraid I don’t see it.
Not sure if this link will post, but I'm guessing this technique is not achievable with porcelain tile, even with a decent pair of nippers?
DIY Tiling Forum
Retroelec,
Qwerty,
Retroelec,
Qwerty,
