Discuss Damnable marble mosaic border tiles! in the British & UK Tiling Forum area at TilersForums.com.
MsCabbage
I am having real trouble using these mosaics as a horizontal border halfway up my travertine walls.
REAL TRAVERTINE MARBLE MOSAIC BORDERS TILES ONLY £1.50 on eBay, also, Tiles, Bathroom, Home Garden (end time 13-Apr-09 1602 BST)
This border is actually in 3 parts with the grey strips being seperate to the middle part. I am having to use about a million spacers and worry about them trying to sink too far into the adhesive.
I was hoping someone could impart some stress reducing tips to help me using these evil little blighters :devil:
silver
As Jay says make space for your mosaic to add after all tiles in....you can flush it off against them then when you add it.
If the mosaic grout space either side of the mosaic is suitable size 1>2mm ( Using plastic trim ....the trim section that goes behind the tiles...says homelux or ? ).......use long lengths of trim and push that part in as large horizontal spacers between lower / top tile and mosaic........then play with pegs or whatever for the verticals....The trim wont make you 2mm....its thinner than that but will be even..........I have a few lengths of L shaped trim larger size for thicker tiles ...that works well for me. On short lengths I used a 1m aluminium ruler beofre that....that was just right at 2mm thick.
Have fun...before tourettes kicks in !
Degs
jay
good we have a tradie thanks silver now you have step 1 and step 3 step 2 is optional depending on border thickness most borders are way thiner so once wall tiles set you need to back fill for the border to comeout flush with the rest ,this is how i have overcome this issue,using a piece of off cut tile make yourself a running screed (bear with me )if your borders are 6mm thick your running screed needs to be 9mm deep fill your border recess with c[b adhesive an using your running screed (which is shaped to go into recess and remove exes leaving you a more workable depth once dry apply adh and set your border its time consuming but you get a near perfect job :8:
smurf21
Reply to Damnable marble mosaic border tiles! in the British & UK Tiling Forum area at TilersForums.com
A long post and not tiling but I hope someone can help, I'm trying to get some decent...
Musivarius
K
Hi, I'm having my ensuite refurbished with ceramic wall tiles laid in a brick effect with a...
10K
David - Tradetiler
K
Morning All. I have 3 wetrooms on a anhydrite screed coming up and I am initially thinking of...
10K
MTiler
Sup fellas, Okay to here is a new job. Glass. I am using the adhesive strips for the mosaics...
Taylormade
11K
Rizzle from the Portizzle
    Votes: 14 9.3%
    Votes: 11 7.3%
    Votes: 44 29.1%
    Votes: 18 11.9%
    Votes: 36 23.8%
    Votes: 21 13.9%
    Votes: 18 11.9%
    Votes: 16 10.6%
    Votes: 7 4.6%
    Votes: 4 2.6%
