Wetroom, Anhydite, Ditra, Mosaic
would using a slc not be a quicker way to fill the cavities ? would there be any drawbacks using this method ?
I would cover the whole floor including the tray with the ditra matting then tank the walls using kerdi membrain over lapping onto the ditra then if you want to tile straight away use tile masters 30 leveller and skim over the floor make sure you still have the slopes in the shower area. you should be able to have a guick sandwich and then your ready to tile I would use tilemasters anafix for fixing the matting and tilemasters ultimats for fixing the wall membrain and the tiles job done in a day? don't forget to cover the ditra joins with kerdi 100mm jointing
If ur waterproofing the floor with Ditra u must use 125mm Kerdi Band and use Kerdi Coll to stick it down, that will give u a waterproof seal. Tile adhesive is not good enough. If u haven't used Kerdi Coll before, be aware it sets in no time, it's super rapid!
used it last week in wet room off in10 mins came part of shluters tanking and wet room kit best tanking kit by far
    Votes: 9 5.2%
    Votes: 17 9.9%
    Votes: 12 7.0%
    Votes: 49 28.5%
    Votes: 21 12.2%
    Votes: 40 23.3%
    Votes: 4 2.3%
    Votes: 5 2.9%
    Votes: 24 14.0%
    Votes: 19 11.0%
    Votes: 17 9.9%
    Votes: 8 4.7%
    Votes: 5 2.9%
