Discuss Day rate in the Canada Tile Advice area at TilersForums.com.
AMtek
prime mate
Depends what addy you're using, a lot of tubbed gear doesn't need priming first but you shouldn't be using ready mixed in wet areas or with tiles outside the dimensions that are acceptable for tubbed adhesive. You will be best off using powdered cement based adhesive for all tiling and following the priming instructions on the adhesive bag, if you follow the manufacturers recommendation you will be covered if there is a problem with the adhesive.
Reply to Day rate in the Canada Tile Advice area at TilersForums.com
Can anyone tell me going rates please £30m2 ceramic and porcelain or £205 day rate Starting at...
Hello one and all, I have a 240m2 floor tiling job to price, including a tile upstand edged with...
py rookie
torquay,devon
Business Name
paul the tiler
Day rate
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
