Decent Floor Tile Adhesive for Wooden Floors
I did a floating floor with granfix ultimate flex, what a nightmare, i will never tile a floating floor again with it.
sorry but i ont tile floor boards had probs in the past had to learn from my mistakes board it
i dont tile floor boards either i use ply or the the green 6mm boards that tops sell then spf
So there's me and you for sticking directly to the boards and two others for plywood overlay. Nice, I think there's still some room in the market for an easier/more trusted brand that can stick directly to solid tongue and groove floor boards. Fastflex and the Larsen's gear (which I saw promoted at launch at Expotile 2002? I think it was) is still yet to be rivalled by a brand that requires only as much work as a cement based adhesive found in a bag, the one we use daily and trust.
So there's me and you and GAZ for sticking.............................................................
I completley agree with dan and gaz on this one, ive used fastflex on t and g numerous times and never had a problem but my reason for opting for ply is because pepole are changing tiles like wall paper these days. When its plyed its easier to take out. Anyone ever tried to remove tiles stuck down with fastflex🙁
the reason is i try to do it the cheapest way so your more competitive with other quotes for customers
Once took 2 tiles up where plumbers pipes were wrong in bathroom after 1st fix.NEVER AGAIN!!!but then anyone who has a floor tiled thinking you can just roll it up out of the way if theres a problem,should have carpet,fitted again...filthy bas***ds!!
i personlly would ply first ,but i am itching to try dittra matting though.
as for granfix ultraflex i found it ok
tony
    Votes: 9 5.2%
    Votes: 17 9.9%
    Votes: 12 7.0%
    Votes: 49 28.5%
    Votes: 21 12.2%
    Votes: 40 23.3%
    Votes: 4 2.3%
    Votes: 5 2.9%
    Votes: 24 14.0%
    Votes: 19 11.0%
    Votes: 17 9.9%
    Votes: 8 4.7%
    Votes: 5 2.9%
