Guest viewing is limited
Discuss deep slc in the UK Tiling Forum area at TilersForums.com.
do the maths
1.6 kg per sq m per mm
eg
3.0 x 3.0 room size
hang on i need my calc
9 sq m room size
1.6 x 9 = 14.4 kg
14.4 kg x 30 = 432kg
432kg / 23 kg = 18 or 19 bags
19 bags * £ 20 = £ 380 ish
insulation boards
6 ' x 3' = 1.67 sq m per board
6 boards 30mm thick + adhesive £ 250 ish and a lot easier on the back
if and if you dont get them level then skim over the lot with a coat of slc
Carol Vordamore checking out
please note the above is only rough but you get my gist
Reply to deep slc in the UK Tiling Forum area at TilersForums.com
Hi I asked the Wunda technical department if I can just use a Ditra mat only and not the SLC...
Moved this as I incorrectly posted in the Pro forum! Hi all, Finally getting to lay the tiles in...
kilty55
edinburgh
deep slc
