Discuss Different substrates in one job in the Australia Tiling Forum area at TilersForums.com.
rj1884
Hello. Went to look at a job yesterday where the customer wants a downstairs utility room, entrance hall and living area tiled using porcelain tiles following the flooding of the whole area. The substrate in the utility room is currently green chipboard. The utility room runs into a large entrance hall area which is concrete screed which has been down for many years. The screed will be prepared and levelled appropriately by the customer. My question is relating to the expansion joint from the utility to the entrance hall. Would you guys remove the chipboard and replace with ply. I was thinking of overboarding the chipboard then tile straight to that and the screed with the porcelain tiles. If the screed is sound would you ditra the whole area or go straight to the screed. If no ditra is used would it be a case of putting in an expansion joint where the substrates meet or do you have to use ditra as well.
My plan is to get the screed brought up to the level of the utility room floor if possible.
Thanks in advance.
Q
Qwerty
White Room
Thanks in advance.
That worries me....
Reply to Different substrates in one job in the Australia Tiling Forum area at TilersForums.com
https://www.tilersforums.com/threads/tiling-on-mapei-renovation-screed.91864/post-964717 Hi...
gamer1
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
