Guest viewing is limited
Discuss Ditra and anhyfix in the Australia Tiling Forum area at TilersForums.com.
Ajax123
1,213
Lincolnshire
Schluter can neither recomend nor otherwise as they have no test data to support one or the other. It would be up to the addy manufacturer to say if their gear sticks the mat down. My experience says yes...Anhyfix sticks down ditra
Ajax123
1,213
Lincolnshire
as long as mc is below 2% which equates to approx. 82%rh on the box
And if you do that with a cement based addy at that moisture level it will fail within weeks... The sulphate laden moisture will react with the calcium aluminates in the cement forming ettringite which will cause the bond to break. An acrylic primer will not help because at this moisture level it will emulsify and further weaken the bond between the adhesive and the screed. There are NO cement based adhesives that I am aware of that can be used on anhydrite at moisture levels in excess of 75% rh or 0.5% moisture. 82% rh is way below 2% probably around 0.8%. 1.5% will give you an rh reading of 92%. In this instance schluter are offering bad advice. If you follow it... well...its up to you.
Reply to Ditra and anhyfix in the Australia Tiling Forum area at TilersForums.com
Hello guys. I came upon and registered with this forum while doing some research on decoupling...
5K
Hi everyone, I'm tiling a 150 meter square meters onto a anhydrite screed. Laitance has been...
hats67 - Yesterday at 11:48 PM Add bookmark #1 Hello guys. I came upon and registered with...
As an introduction, I'm a DIY home owner who has gutted the bathroom in a house built in 1980...
Tony R
oxfordshire
Ditra and anhyfix
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
