Discuss Ditra concrete floorboards in the Australia Tiling Forum area at TilersForums.com.
Stef
If you had to fill the squares with slc then tile you are then defeating the purpose of the Ditra as it won't decouple, you are creating a join between the slc & adhesive.
Filling the squares & tiling should be done in one hit so the adhesive is locked into the Ditra mat.
If you get a chance go on the Schluter training course, it's only 2 days but worth it.
Reply to Ditra concrete floorboards in the Australia Tiling Forum area at TilersForums.com
Hi I asked the Wunda technical department if I can just use a Ditra mat only and not the SLC...
Hi All, I’m ripping out a failed existing tiled floor. Tiles had not been back buttered so...
Sean Kelly
Ruislip
    Votes: 7 5.2%
    Votes: 13 9.6%
    Votes: 8 5.9%
    Votes: 39 28.9%
    Votes: 16 11.9%
    Votes: 33 24.4%
    Votes: 3 2.2%
    Votes: 2 1.5%
    Votes: 20 14.8%
    Votes: 18 13.3%
    Votes: 15 11.1%
    Votes: 7 5.2%
    Votes: 3 2.2%
    Votes: 3 2.2%
