Discuss Ditra Mat / Tile safe / under tile heating. advice needed. in the UK Tiling Forum area at TilersForums.com.
de la mace
Hi guys,
My trade is a qualified plumber/heating engineer for the last 25 years. I often take on the tiling of my bathrooms where the customer does not want anyone else involved. Over the years I have fitted lots of ceramics, porcelain and recently stone. i have always taken the advise of the suppplier with the use of adhesives, primers grouts and the like.
i have recently taken on 160m2 of trav in three bathrooms, where someone else started and was really out of his depth, lippage on every tile - no way - he got thrown off the job by the customer. i am left with floors - detra Mat - tile safe membrane (wet rooms floor) - electric matt. my question is what should my floor build up be Detra Matt / Electric matt with latex / membrane or Dertra Matt / membrane / Electric matt with latex.
i would be grateful for any suggestions.
Andy.
Pebbs
Where were you when I needed you de la mace...no heating for 5 days now...I was begining to resemble eskimo nell!
Andy are you saying he left the ditra on the top? because he should have done its the last thing to go down. If your levels are right then you can go ditra on top of the heating mats, if your not so sure then level it and then put the ditra on top of that.
What is the substrate? dont tell me wooden floor boards, or I may just combust.
Pebbs
Time's Ran Out
:welcome: Andy.
You can lay the Ditra matting above or below the UFH -according to Ditra - but it is more effective above and has better decoupling properties. Would suggest it would also provide a better waterproofing aspect.
With Tilesafe membrane you must check the wattage of the mat - I believe they only recommend 100w/metre output.
Have fun.
The Legend; Phil Hobson RIP
A very interesting question, as above Ditra, Dural etc. say de-coupler can be laid above or below ufh. Yet Dural have informed me recently that a 4mm trowel is ideal to bed the fleece into ( which I did know ) for the CI membrane to work most efficiently . My only concern is if you lay the ufh mat, on average 3mm. Then use a 4mm trowel to bed the CI mat, you will not achieve full coverage to the fleece.
The last job I did using Ditra over the ufh mat I used a 10mm half moon trowel, I am sure I achieved 100% coverage. 4mm is fine if you are laying Ditra onto flat substrate, and then using ufh over the top. But if you need to lay Ditra over ufh you will need a deeper notch trowel imo:thumbsup:. Hope this makes sense.
Gazzer
But wouldnt you SLC 1st ?
Dan
Admin
Staff member
5,094
1,323
Staffordshire, UK
Just bumping this thread. If it's not a current topic then don't worry about it for now. Other threads like this can be found in the main tiling forum. If you do want to reply to it, please do. Your information may add value to somebody reading the forum in the future.
Reply to Ditra Mat / Tile safe / under tile heating. advice needed. in the UK Tiling Forum area at TilersForums.com
Hi I asked the Wunda technical department if I can just use a Ditra mat only and not the SLC...
Hi, hoping for some advice.... Had a anhydrite screed laid early Feb. Looking at laying 20mm...
I have a customer who lives in a 200 year old property. The lounge floor he wants tiled which...
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
