Discuss Ditra Matting Adhesive in the UK Tiling Forum area at TilersForums.com.
grumpygrouter
Why do you find it fiddly russ..?..
Cos I've only used it once and I spent quite a while trying to ensure that the dovetails were filled with addy. I found it kept rolling out so I had to go back over in different directions to get it as full as possible. Apart from that, it was easy. it looks straight forward when you see the videos, but that part caused me a little concern.
grumpygrouter
I've got 2 x 2m shower rooms to do Dave, and the customer is not keen on ply because of the lip created by it and the tile. I thought that the Ditra would prevent both water penetration and any movement cracking my joints, and leave them with an acceptable lip to carpet to.
For 2x2 bang the tiles down with Fastfex.
DHTiling
No probs.....but i would over board first with 6mm ply( if the chipboard is solid ) then stick the ditra down( 2 part adhesive ) and seal the joints to create a water proof floor.....then tile on top with normal flexi......but the floor must be solid to start with....hardi will give you a water resistant floor but not water proof.....
DHTiling
I would use Ditra with ardex AF200 or Evostick or similar onto chipboard provided the floor is solid. After all you are sticking a fleece to wood!
Kev
Iv'e never really been a fan of tiling/sticking directly to chipboard.....do you think either of those will work well on chipboard kev..?...
grumpygrouter
I recently laid travertine down on a T&G Chipboard floor, i was advised by a local tile firm to seal the boards first and then mix 50/50 water and Ultra flexi prime and use that to mix up the addy and away i go. Would that be the same idea Grumpy?
No mate, fastflex is BAL's ultra flexy stuff for wooden floors. It doesn't set hard as such, more like a really really dense sponge.
If the floor was proper solid, I personally, and you didn't want a lip, would use Ardex-flex 7001 after priming the floor with Ardex P51. You will use less than a bag for that area. Cheaper than fastflex too.
However, if you are looking for waterproofing as well, ditra will be fine, again as long as the floor is solid.
Reply to Ditra Matting Adhesive in the UK Tiling Forum area at TilersForums.com
Hi I asked the Wunda technical department if I can just use a Ditra mat only and not the SLC...
Hi All, I’m ripping out a failed existing tiled floor. Tiles had not been back buttered so...
    Votes: 5 4.0%
    Votes: 11 8.7%
    Votes: 8 6.3%
    Votes: 36 28.6%
    Votes: 16 12.7%
    Votes: 31 24.6%
    Votes: 3 2.4%
    Votes: 2 1.6%
    Votes: 19 15.1%
    Votes: 18 14.3%
    Votes: 14 11.1%
    Votes: 6 4.8%
    Votes: 3 2.4%
    Votes: 2 1.6%
