I've used glue and flexi rapid, just that with the rapid you have to keep off it til set or you'll break the bond.
might be a bit troublesome when you want to lift a tile to check coverage as you'll pull the ditra tooIf I was to use a standard set, could I lay the entire area, then work on it? Ie. setting tiles out, then fixing..
might be a bit troublesome when you want to lift a tile to check coverage as you'll pull the ditra too![]()
With standard set, would I be able to set out/dry lay while it's going off? Or is there a point that I'd just have to stay off it!?! I've got a feeling I'm gonna be losing a lot of time tomorrow. 🙁
hardiebacker don't recommend their boards over concrete floorsSLC'd today. It was screed over concrete and suspended floor.. Cracked on join, and a couple of small cracks elsewhere on the screed.
hardiebacker don't recommend their boards over concrete floors![]()
durabase? and maby you using wrong tool for matting? :lol:
