H
Honest Jon
Hi all and thanks in advance for any advise.
I am not a professional and if I am stealing trade secrets please just advise me and I will go away. I am a competent DIY person and can offer advice on many other subjects that come up from time to time. I read a number of topics earlier. You can see a little more in my introduction where I said hello. Anyway.
I am about to tear out my en suite and redo everything, I will be tiling the walls and floors and my first question is regarding the floors.
Do I need to put down ply? I have 22mm moisture resistant T&D chipboard flooring, which is well laid and fixed with ring nails, I will further secure with screws when I remove the current wood flooring, It is solid and is only a small area. I do not mind putting down ply as it is a 30 minute job but would like to know if it is required and if so why? What would the alternative be as far as priming the area, and if this is likely to be more time consuming I will lay ply. What thickness if it is required.
Thanks for the help.
John
John
