Discuss Does size really matter? in the America Tile Forum area at TilersForums.com.
Hi there
I have had some tiling done in a downstairs toilet. Tiler has said that I have made it more difficult for him as I changed my mind from 2' x 1' tiles to 1' x 1' (I am sure at the time he said it would not make any difference) which needed more cuts. Would this be true?
He has used 12 sq m of tiles. Another tiler has said 8 sq m max for the area covered.
Thank you for your opinions!
What problem do you have? I dont really understand what you are asking for here?
If I had quoted for a certain tile and the client changed it, if that were an issue, I'd tell them prior to commencing works.
For example, one of the walls has two 1' x 1' tiles plus a cut-off of about two thirds of a tile. If I had chosen the 2' x 1' tiles, he would still have had to cut a tile. I was querying whether this would make that much difference to the job considering the room is about 2' 8 " by 4' 6" (doorway on this wall). He is saying it took him longer. Apologies if I am not explaining very well.
You have made a very valid point about the fact that he could have said something before he started the job.
Reply to Does size really matter? in the America Tile Forum area at TilersForums.com
Hello, I am a noob trying to tile our shower. Since the old tiles were taken off, some of that wall material has been taken off as well, so everything had to be smoothed. After smoothing with some...
  • Question
  • Question
Hi all, I've laid some Arditex NA over the kitchen floor area (not under cabinets. The area is 4.5m x 1.8m. The top third of the room is totally level. The remainder of the room has a slope...
