Discuss dome ceilings in the UK Tiling Forum area at TilersForums.com.
borgie
Hi,
we have 2 ceilings to form and tile in marble mosaic. one is a steam room, this a dome ceiling,the other a shower, which has an arched ceiling. We will make the dome from wedi boards. has any one got any tips for setting out and fixing? the client wants all the joints to be the same and no cuts. there is a 1mm tolerance in a 2m length through out the whole job. on the ceiling we will have a tolerance of 0.5mm.
our plans is to get some centre lines pinged, then cut the sheets down to strips of 1. then do a 1/4 of the ceiling at a time. not being able to put them down dry is the problem. we did think about fixing them 1 by 1. there's about 3.5m2 in each ceiling. so any advice or tips would be greatly appreciated.
simon
The Legend; Phil Hobson RIP
Hi Simon, this is the nearest thing I have done to a dome. Maybe it might help.
Spud
it may be best to suggest using a penny round mosaic on the celing or a hexagonal mosaic this will give you a ceiling with out obvious cut peices throught the field of the dome and the joints sizes are easily adjusted with the penny rounds ,you will see cuts where it meets the wall linings ,I would get the dome made out of fibre glass as this will be easily and cheaply done at a plastics factory if you have one local to you and fix and grout with epoxy, hope this helps Gary
borgie
the ceiling were changed to two barrel ceilings. so there was no problems at all. i have posted a few pics, but there was not really enough light. sorry it's taken so long, it's been a busy couple of weeks.
Reply to dome ceilings in the UK Tiling Forum area at TilersForums.com
Hi, Hope everyone is well. I'm after some advice please. I'm currently having my bathroom tiled...
We recently completed the (rectified porcelain) floor tile installation in the bathroom and...
TF Group Please Join
dome ceilings
Tags
usa
Tilers Forums on FB
