Discuss Door threshold/trimming door in the British & UK Tiling Forum area at TilersForums.com.
F
FreeD
Hi all
I've been reading through loads of posts some great info...i have a few of questions...
went to look at a job today...customer is using 7mm ceramic tiles.
firstly the door needs trimming it currently just clears a 7mm tile. Firstly i will be plying over existing boards 12mm then using 10mm floor trowel...from posts i've read on here my understanding is that although i'm using a 10mm floor trowel once tiles are stuck down the adhesive will be compresed to more like 6mm.
So to be on the safe side i should ask the customer to trim the door by 2cm?
I'll offer to trim the door myself with the Fein (i plan to invest in one) and charge accordingly...whats the best way to do this using the Fein? mark off 2cm line and then cut across freehand (i'd worry about getting it straight)?
I noticed the door was hollow also will this cause me any probs?
And the last question! At the door going by the above measurments there will be a gap to floor of 25mm can i get a threshold to this exact size from b & q etc? or do they have to be packed out in some way? and cutting it to size i guess i can just use the Fein?!
Thanks Aaron :thumbsup:
F
FreeD
£10! to little m8...(in my opinion) i'd charge £25 min and put it down as a variation. I mean lets be honest what are the chances the customer is going to take the door off saw it with a handsaw and re hang it...for the sake of £25.
What is the name of the door trimmer you have?
any help with other questions?
cheers
UKTT Darren
TF Official Sponsor
Subscribed
195
828
North East
The trimmers are called a carlton door trimmer, not cheap though cost about £230 if you can still get them, does the job though in about 20 seconds with the door still on the hinges, great piece of kit. Personally i wouldnt use the fein, take it off and use a saw or electric plane, make sure you dont rip off the vaneer of the side of the door, come at it from both sides
F
FreeD
In case any1 is having trouble searching these its spelt 'karlton'
Looks like they have been discontinued don't know why. There are similar tools on the market as above.
Enduro from previous posts i see you have one of these...how often do you have to replace the blades? what type of blades do u use?
Out of interest Darren why wouldn't you use the multimaster? I thought the E-Cut blade was intended for this job?
Aaron
White Room
Reply to Door threshold/trimming door in the British & UK Tiling Forum area at TilersForums.com
I'm looking for solid answer or opinion. We had some windows removed on an exterior wall and...
Hi, 1st time tiling, decided our ensuite would benefit from being a wetroom. Quick question, any...
    Votes: 9 5.8%
    Votes: 15 9.6%
    Votes: 11 7.1%
    Votes: 46 29.5%
    Votes: 19 12.2%
    Votes: 37 23.7%
    Votes: 4 2.6%
    Votes: 21 13.5%
    Votes: 18 11.5%
    Votes: 17 10.9%
    Votes: 7 4.5%
    Votes: 3 1.9%
    Votes: 4 2.6%
