Discuss Dot and Dab in the British & UK Tiling Forum area at TilersForums.com.
Colour Republic
I'm doing a plastering job at the moment and I came across a new product... well I think it's new, i've not seen it before
Everbuild Product Range - Everbuild
it's a dry wall adhesive but it says that you can plaster after an hour of fixing the walls! I asked the supplier what they think of it (they only stock plaster and plasterboard, main suppliers for Brighton) and they said it's amazing but only if you have fairly flat walls already, if it's put in to bigger blob it takes a while to dry... anyway i thought you guys might like to know as i'm sure you could tile in an hour also. i would have thought plaster would crack alot easier than adhesive would an hour after installation
what do you think?
Colour Republic
Ang how :yikes: much will that be...........:lol:
I didn't ask but thought I saw it was about 6 quid a tube and was told it would do 5 boards, so really it isn't bad, would cost a bit more opposed to bagged addy but if you could crack on within a couple of hours it's worth it IMO
Colour Republic
I like Everbuild, I still think Gripfill is still the best gap adhesive going, you can't beat the first on the block, so i have faith in their products.
It will take up variation in walls just not massive amounts, i'm taking more than 2.5" here. anything more and i'd stick with traditional Dry Wall addy. It works like expanding foam, but doesn't push the board out and sticks a lot better if that helps
Reply to Dot and Dab in the British & UK Tiling Forum area at TilersForums.com
Hi all what adhesive would you recommend for dot and dabbing foam cored backer board onto...
    • Friendly
Hi. We've had a bathroom installed with electric mat underfloor heating in a new extension. The...
Hi all, I am in the middle of renovating my bathroom. First of its kind for me! The walls were...
Dot and Dab
    Votes: 9 5.6%
    Votes: 17 10.6%
    Votes: 11 6.8%
    Votes: 44 27.3%
    Votes: 21 13.0%
    Votes: 38 23.6%
    Votes: 4 2.5%
    Votes: 3 1.9%
    Votes: 22 13.7%
    Votes: 19 11.8%
    Votes: 17 10.6%
    Votes: 8 5.0%
    Votes: 5 3.1%
