Discuss Dot and dabbing adhesive for foam core backerboad in the UK Tiling Forum area at TilersForums.com.
Dan
Admin
Staff member
5,088
1,323
Staffordshire, UK
You need plasterboard adhesive and they need to be dotted every 300mm (12") and then mechanically fixed with drilled, plugged screws - For Aquapanel or similar cement-board.
If it's Marmox-type foam board with blue foam in it. Then you'll need to spread tile adhesive that's flexible (S2 in UK I THINK) as if you're tiling the boards to the wall. As this will give you protection against the weight. Don't dot and dab those types of boards. They're mean to be spread, on the wall, then stuck to that as if a big tile.
Reply to Dot and dabbing adhesive for foam core backerboad in the UK Tiling Forum area at TilersForums.com
I'm having a nightmare trying to establish product info from distributors. For example...
    • Friendly
Just wondered what would be best? The original tiles had a few hairline cracks from the house...
England
What member type are you?
  1. DIY Wall and Floor Tiler
    Votes: 5 4.6%
    Votes: 8 7.3%
    Votes: 6 5.5%
    Votes: 30 27.5%
    Votes: 14 12.8%
    Votes: 28 25.7%
    Votes: 3 2.8%
    Votes: 2 1.8%
    Votes: 19 17.4%
    Votes: 18 16.5%
    Votes: 13 11.9%
    Votes: 5 4.6%
    Votes: 3 2.8%
    Votes: 1 0.9%
