Dot And Dabbing At Its Best.
the tiler who got away with the dot and dabbing is nicknamed Mr. blobby
he has a trail of failed floors behind him mostly ufh porcelain floors doesnt back butter or use a notched trowel at all , his work looks fantastic when it is finished, magazine/ brochure quality but after a few months the tiles start to come loose
blobby............= B&B 🙂
.....and if you later try to contact Mr Blobby you will miraculously find his phone no longer returns your calls!
In the real world, and when working on old houses and refurb bathrooms for builders etc, you get bad walls and your gonna need to build them out in places which means adding some dabs! I always use the notch trowel on the wall and butter the back of the tile if dabs are neeeed, add them to the tile. You can't do no more. But there is a limit ofcourse
Could you not use a 8 or 10 mm even 12mm float to even the surface out??
Chalker,
Flintstone,
Chalker,
Flintstone,
