travispuk
Hello everyone,
I am planning on using Dot & Dab with a Mapei single part flexible tile adhesive of 12mm NMP boards to a fairly rubbish brick wall. My plasterer (a really good guy) suggested I should PVA bond the brick wall prior to doing the d&d. I have done the PVA solution now, but have been spooked by a number of threads here talking about not using PVA for the prep. I know that these have mostly been relating to putting down tiles and tile adhesive, but was wondering if I should not be relying on the PVA bond on the brick wall for the d&d now?
Given that I have already used the PVA, should I also add a coat of SBR or will the PVA be fine for this application?
Thanks in advance.
ps. I have also used 5 x stainless steel screws for each board to provide a fixing to the brick wall. Primarily to assist in making a nice flat surface and positioning as the bricks are pretty horrid, not a problem in a 120yr old house that had a nice thick wet plaster covering.
Thanks in advance.
