dot n dab boarding....
Sheet really, bugger,hope all them hundreds of houses ive plastered are ok with all that additional movement from putting thousands of clouts in em, now im panicking 🙂 🙂 🙂
Lol, I think boards are screwed these days for no other reason except speed.
How so Ali? Nailing is much faster IMO
Screwing is the prefered method because of less movement as Neal says. If you've had to repair as many skimmed walls as I have where the plaster has popped over the nail heads you'd agree Wilder 😉
Nailing is hardly a bodge but screwing is much better
if its nailed right CR it should be fine,if you break the paper then the nails will pop as you say,but ive also seen loads of screwed ceilings/partitions with the same problem,folk going at them with the screw guns like a man possessed by the devil himself,going right into the board.
i do screw all mine now though,just cos every job i go on they always get screws,i hate the blinking things though,splinters off them little buggers are horrid 🙂
Surely the screwguns are quicker?
Issue 1 - srews vs nails - nails grip in one direction radiating out from their shank. Screws grip in 3 directions up/down and laterally - because of their helicoil. So screws are always going to hold things more secure than nails. Issue 2 - nail guns vs screw guns - time wise I would say nail guns insert more nails per minute than screw guns, though the difference may only really be noticeable on a large surface area. Issue 3 - nail and screw heads "popping" plaster skim - I would say both equally capable of that - try hitting a plaster skimmed drywall with a mallet and watch the nail and screw heads appear! Issue 4 - will nailed drywalls fail quicker than screwed walls? - depends on weight exerted on them - in other words it depends on weight of the tiles - but I would suggest that a fully dry plaster sheet wall will easily hold the weight of 12mm tiles even if drywall is nailed. But if its wet or if its a ceiling - then maybe not - but then if plaster is wet it will fail no matter how its fixed!
Bag of board addy £4.80..... Bag of tile addy £11 ..... Now what was the question again?
Screws tend to be used as they can b loaded in a machine and there is a lot of metal stud used these days and screws offer a more solid fixing than clouts. Not sure if ou can get a clout nail gun??
:lol::lol:
what is the correct method of dot n dab boarding onto plasterd wall... Currently in the process of doing me moms bathroom. Ive moved the bath over and there is a gap either end and a 12.5 mm board either end will sort all my problems... I plan to prime the plaster, board and then tile.... But can I use the adhesive I plan to use for the tiles or do I need drywall adhesive? and if my method is incorrect please let me know cheers.
To be fair Alan the important question was never asked and that is how he plans to get over the 12.5m lip he would create in the wall at either end of the bath after fixing plasterboard? Whacking great big tile trim? or now having to board out the rest of the walls to suit? and then possible issues with doors if on the same wall
A picture of the job might have shortened this thread by a couple of pages..............:8:. Screws over nails..................:thumbsup:
