Guest viewing is limited
Discuss drilling porcelain in the UK Tiling Forum area at TilersForums.com.
Deleted member 1779
We supply them as a pack of 4 for £29.99 (Members get discount)
But we are THE ONLY COMPANY to supply a full size range from 6mm to 125mm. This means that professional tilers have access to diamond drills for any situation most importantly the service pipes but also for bespoke sizes, like 53mm for a button press for a loo.
We are aware that there are other companies out there that supply a limited size range (mainly the smaller sizes) and a limited range of cores.
But our system is easy to use, a pack will last about 40 holes and we try to ensure a fair price
The guide plate makes life easy to start.
We do a lot of exhibitions and provide a lot of technical support...
You get the full service with us !
And we are a cheerful bunch too !!
And Finally if you ever need PROOF of our customer service and product quality then check out this link
One Thousand PLUS units sold. ZERO complaints.
Just click it.... To check it...
Deleted member 1779
We're also demonstrating superb value for money through this recession with a price of only £7.15 per drill with the multipack.
The PlasPlugs drills were running at £15 EACH !!
Please note earlier this year Plasplugs filed for bankruptcy so obtaining replacement drills may prove difficult. However in the last half of 2009 they salvaged some of the company to reform although its too early to say what ranges they will scrap and what they will continue with.
Our message remains the same:
365Drills are aggressive on prices for those who want high quality professional diamond tile core drills and hole saws.
Reply to drilling porcelain in the UK Tiling Forum area at TilersForums.com
A question about mitering and matching epoxy colour I'll be working with some pinkish matt...
drilling porcelain
