Discuss Dry screed over ufh and slc in the Canada Tile Advice area at TilersForums.com.
Ajax123
1,213
Lincolnshire
Yes you can but you could end up with a heck of a depth. You would need to prep the existing and then lay a minimum of 50mm screed reinforced with fibres or d49 mesh. An alternative would be a thinner gypsol screed (minimum 30mm). There are various other options as well but it all depends on depth. A thick bed levelling compound like Arden a35 is another option if drying times are a problem. Whichever you go for you would need to make sure the substrate is prepped properly.
Ajax123
1,213
Lincolnshire
So a normal sand and cement is out of the question then?
Not out of the question just depends on the depth you have available. Why not just use a levelling compound to take out the 30mm fall??
Ajax123
1,213
Lincolnshire
Well....I started taking up the old tiles and it pulled up the floor with it including slc , ufh and screed which had turned to dust!
Oops. I guess that decision is made then :)
Reply to Dry screed over ufh and slc in the Canada Tile Advice area at TilersForums.com
hello new here but wished i had found and asked before screed and ufh down but here goes. We...
Moved this as I incorrectly posted in the Pro forum! Hi all, Finally getting to lay the tiles in...
gamer1
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
