Discuss Drywall T-square or framing square in the Canada Tile Advice area at TilersForums.com.
Yes, I always get my walls square when re-boarding. Most important on the Bath and shower walls but also worth getting spot on If you have a Basin unit butting up against a wall. I have the old Stanley folding square when it was well made. Before that I would offer up plasterboard with two good edges which works equally as well but more awkward. I don’t know what the cheap folding squares are like but any decent sized square will do the job.
Yeah, a drywall T-Square is no good. There will be a great big gap on one wall. You want something that touches both walls. The T-Squarr is invaluable for plasterboard cutting though.
dg-1984
288
Glasgow
I bought a framing square from Screwfix was under £8 and seems decent I checked the walls in the toilet I will eventually tile and there is a slight bow in the middle probably about 4-5mm over a length of 1m.
Can I skim the wall to bring it out or am I thinking too much about it?
If I can, would I just use a thin layer of tile adhesive and once set and flat then tile as normal?
Albert
1,253
Gateshead NE8, UK
I tend to use these they come in 2 sizes
dg-1984
288
Glasgow
90 percent of the walls and floors we do are out ,either old houses or the timber warped ,or bad workman ship ,it will always be the same
So am I best to just add a little extra addy to that area to bring it out the few mm, or best getting it flatter before tiling?
https://www.NoLinksToThis/p/magnusson-framing-square-16-x-24-405-x-610mm/6641v
This is the one I bought seems good for you the money, also good round external corners.
Reply to Drywall T-square or framing square in the Canada Tile Advice area at TilersForums.com
  • Sticky
  • Question
