Discuss dull mosaics after grouting in the British & UK Tiling Forum area at TilersForums.com.
oleras
Howdy folks, first post.
I tiled my bathroom last week with ceramic wall and floor tiles. I put in a mosaic ceiling to floor drop behind where the sink will be and also as a bath surround. natural stone/marble mosaics.
the thing is i didnt seal them before grouting them:mad2: . Now they are as dull as dishwater !
I went back to the tile place and they sold me a ph neutral cleaner to scrub them with, they look great when they are still wet but dry to a dull again, i have tried buffing them and buffing them but no good.
what will i do next ? i want to get them sorted before i seal them or would sealing them give me back my shiny mosaics ?
broken link removed
grumpygrouter
Sealing will only seal in the dullness. It sounds to me like you need to clean the mosaic bit with a Cement Residue Cleaner. Lithofin do one, as do HG. Follow the instructions carefully as they are acid based. Hopefully this will clean your tiles up ready for sealing. Again, both companies mentioned do good products for sealing stone.
Grumpy
wetdec
Can we sort of get this right :
Travertine should be sealed after grouting if you seal it before you are closing the pores of the stone and reducing grout grab.
Fixing stone commands a premium because its a longer process than ceramics and takes understanding, sealing it first to make the job quicker contradicts the latter.
When you seal or intensify after grouting you can only seal in what you have left on the tiles. If the tiles are clean then you dont get a problem.
Using a grout such as Mapei ultracolour with a propper grout float to grout, leave untill tiles get cloudy (15/20 mins) and wipe any grout from tiles with a hydrophilic sponge rinsing it out after every pass. Leave tiles again untill cloudy and repeat. When tiles are dry dust off the surfave removing any stubourn grout with a stanley blade, when clean seal.
This is how it should be done and your not wasting money on cleaners :thumbsup:
tiler
wetdec
In the factory the slabs are cut from blocks have their surfaces filled either by hand with a trowel or machine with brushes either way the stone is wet. As the stone is filled if there are holes or large pores with air or water in them they do not get filled leaving empty holes or pores after the process is finished. When you grout a Trav floor you do 2 things you fill your grout lines and any holes or pores that are missed at the factory this is why you should always use a fine grout on travertine.
When the floor is dry you seal it to prevent staining of the tiles and grout or intensify it to enhance the colour.
tiler
guy1976
you need to use a ph neutral or alkali cleaner as acid based will etch the stone and leave a rough surface you need to mix the residue remover as directed on bottle apply to stone and leave for about 20mins,dont let it dry on the surface of tiles and work it into stone with a paint brush then clean with lots of clean water, then repeat process untill its sorted
davy_G
Yep, agreed be careful. Spot test the cleaner first
oleras
i have already used a ph neutral cleaner twice (Fila Cleaner, Floor detergent).
It looks fine when it is wet, but when dry it still leaves that "cement" film that comes off if you rub a wet finger over it, and comes back when dry again.
will have to wait till tomorrow to get another cleaner, closed here in Ireland for public holiday, i should be in the pub getting drunk, not worrying about tiles...:grin:
TilingLogistics
broken link removed
If the mosaics were shiny prior to fixing and now they are dull after fixing I can only assume you used a sand based grout! Or you have grout haze all over them! Can you clarify what exactly you used to grout the stone with please before you rush out and buy anything.
Kevin
Reply to dull mosaics after grouting in the British & UK Tiling Forum area at TilersForums.com
Hello, I’ve put up mosaic tiles and some of them (the shiny metal ones) have a protective film...
Our new shower floor does not fall to the drain! A large puddle sits next to the drain. The...
Hi all. After living in my property for over 7 years I've recently discovered the type of tile...
    Votes: 9 5.3%
    Votes: 17 10.0%
    Votes: 12 7.1%
    Votes: 49 28.8%
    Votes: 21 12.4%
    Votes: 40 23.5%
    Votes: 4 2.4%
    Votes: 4 2.4%
    Votes: 23 13.5%
    Votes: 19 11.2%
    Votes: 17 10.0%
    Votes: 8 4.7%
    Votes: 5 2.9%
