Discuss Edge problem replacing floorboards in the British & UK Tiling Forum area at TilersForums.com.
2hapennies
Hi all,
This is my 1st post on this great forum, hope you can help.
I want to ceramic tile the bathroom floor, currently floorboards. Originally I intended to put 6mm backer of some sort over the top, and found this forum while looking for best practice. However having read a number of threads on this, I then thought the best thing would be to replace the boards with 18mm/20mm ply first. But down both sides of the room the existing stud walls are offset from the floor joists which run parallel. Ie. the walls are just standing on the floorboards between 2 joists. So I cant replace the boards between the walls and the nearest joist, so would have to do some sort of patching, yuk. I reckon this must be quite common, anyone got a solution? Or should I just go back to putting thin backer down over the whole lot?
Its not a wetroom, I dont want to raise the floor level by much, the joists and boards are sound with little if any deflection, but a number of the boards are a bit warped/dished. Would 6mm backer be OK on these? I'd appreciate any advice anyone can give, Thanks, 2hP.
2hapennies
Thanks Diamond. Yes thats right. The floor joist is about 20cm away from the wall which stands on the floorboards. The boards run under the wall to the next joist on the other side of it. So I cant cut the boards right upto the wall without undermining the wall structure and floor on the other side. Only possibility I can see is to lift boards at intervals on both sides of the wall, and fit noggins to support the wall, but seems way over the top ( or rather under the bottom!)
2hapennies
Thanks Mike, Yes I think I'm back to giving overboarding a go. But I really dont want to use anything thicker than 6mm, 'cos of step up in doorway, though I've read on other threads that people think 15mm should be minimum. As I said the floor is solid, its just the dished boards that concern me. Is the overboarding likely to crack where the dips are?
2hapennies
OK all, thanks very much for your help and patience.
I've now looked up NMP and SPF, and agree these look like my best bet.
I've found a thread on "whats the best SPF" so I'll have a look at that. NMP versus Hardie? Any views? or are they much the same?
Are there any incompatibilities between different SPFs and overboards? Thanks again, 2hP (Martyn).
trevortine
Let us know how you got on buddy! Remember, every days a school day, learn something new and you'll know the next time, just quick point as well, if you ever have to lay a lot of boards then always stagger them, ie in a brick bond fashion, this prevents having four corners meeting and a potential weak point! Good luck!
Reply to Edge problem replacing floorboards in the British & UK Tiling Forum area at TilersForums.com
Hi I am gping to be tiling a large ground floor flat through out The passage is floorboard...
    Votes: 14 9.3%
    Votes: 11 7.3%
    Votes: 44 29.1%
    Votes: 18 11.9%
    Votes: 36 23.8%
    Votes: 21 13.9%
    Votes: 18 11.9%
    Votes: 16 10.6%
    Votes: 7 4.6%
    Votes: 4 2.6%
