Mortarforker
Correct..I have had too many failures with self leveling compounds..They either don't stick to the primer..Or too much water or not enough water...it has to be the right enviroment for it to work perfectly..I use thinset because I can control how wet I make it and how I can burn it into the flooring beneath..Then I alway's let it dry all the way...Then continue to install a membrane over the top of it..This is just my method and I let my customer know that I warranty my work for 5 years..Everyone has there own way..But this is mine and I trust it..:8:Maybe this has been read wrong..
I take it as cement board cuts around the perimeter of the room and then you screeded over the ufh.. so in theory it is the same as using the SLC's that we use in the uk..but you use thinset instead.. Have i got that right.?
So you are not laying cement boards over the ufh, just around the perimeter as screed levelling heights..?
