Discuss En-Suite Shower - Tanking, Grout and Adhesive advice required in the UK Tiling Forum area at TilersForums.com.
R-Jeffery
Morning,
A complete novice to the site and to the industry so please be gentle.
I have recently had to rip out my shower due to mould and plasterboard damage. Upon removing tiles etc we found that the plasterboard used was standard board and that no tanking was completed either. (Pretty impressive for a 3 year old apartment :mad2:) - I'm assuming based on these failings that the incorrect grout and adhesive was used too.
Anyway I have just had moistureboard fitted and was planning on tanking & getting waterproof adhesive and grout.
I've been reading these forums for some weeks now and wanted some advice on a) what tanking kit to use b) whether waterproof adhesive and grout is required after tanking and if so which to use. c) Will I also need a specific sealant to finish off?
After the mess this has made I really just want to ensure that I cover all basis so that I dont come accross these issues again.
Help is much appreciated! :thumbsup:
R-Jeffery
Picture attached for reference, any help would be much appreciated.
R-Jeffery
From looking on the forum it appears that Mapei is a popular choice for tanking, gout and adhesive. I was planning therefore on going for the MAPEI Shower Waterproofing Kit, I was advised in a tile shop about Mapei ProFlexible for adhesive and Mapei Ultracolur Plus for the grout.
As per the picture the walls are 2.12M high and 0.88M wide with two walls requiring attention.
Are these OK to use? I keep seeing similar questions and comments regarding using the correct type of adhesive and grout to ensure that it remains waterproof.
Really sorry but I'm no expert and would really appreciate a couple of pointers. I have a tiler friend who is fitting this all for me but he is away for a couple of weeks and has asked me to supply all of the products prior to fitting.
Any pointers?? Please help..
R-Jeffery
From reading many of the threads I have stumbled across Mapei quite a few times.
I'm looking at using the Mapei waterproofing Kit, Mapei ProFelxible Adhesive and Mapei Ultracolour Plus Grout, finishing off with the Mapei AC Silicon sealant.
The tiles themselves will be fixed to 15mm Moistureboard. I have purchased some 31x45 Nerea Crema ceremamic tiles with some Expresso (Marble - I think) Mosaic tiles to form a pattern up the middle of the enclosure.
Is the MAPEI kit detailed above sufficient to waterproof and secure the tiles?
Any tips????
bugs183
Hiya.
The Mapei kit will do fine for this job.
I'd be tempted to gun some 'instastick' foam glue (Screwfix) inbetween the shower tray and the boards, alow to dry cut flush. This will strengthen the boards where they meet the tray.
Tank with the kit as instructed, then use the products named above. If you don't tile much i'd say use a slow drying adhesive as it gives you time to play with.
Enjoy!
Reply to En-Suite Shower - Tanking, Grout and Adhesive advice required in the UK Tiling Forum area at TilersForums.com
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
