Discuss Encaustic novice!! in the Australia Tiling Forum area at TilersForums.com.
Time's Ran Out
Be careful grasshopper!
1) have very clean hands and even use surgical gloves.
2) check shades
3) make sure tiles are absolutely dry
3) dust with clean cloth/soft brush
4) impregnate/seal until no more accepted and leave NONE on face of tile.
5) use white fast set flexible adhesive
6) 2-3mm joint
7) fix
8) check grout colour on spare piece for staining
9) thoroughly clean
10)when dry - 48hrs minimum - seal again leaving NONE on surface
11)get paid.
Enjoy.
Time's Ran Out
100% yes - seal before you handle them if possible!
These tiles are neat cement and oil off your skin will discolour them.
Do NOT get them damp, wet, or marked by any means prior to sealing as they will show any imperfections once dry.
If you fix them without following my 1-10 it will be a disaster waiting to happen.
They are like Nottingham paper, if you use a sponge on them prior to sealing, although they may look dry, once you seal them it will dry differently where the sponge has been.
As I said - be careful Grasshopper ! ( that doesn't make me a Master, just one who has the 't' shirt.)
These are not the easiest materials to use and there are no shortcuts in time, so price it right.
simplythebest
228
The top coat of encaustics is powdered marble, highly sensitive as above.
Seal As you take them out of the box and seal them again after laying.
I would put a thin coat of wax before grouting just to help you, even then you still may need a cleaner over them after grouting before the final coats of wax.
enjoy!
Reply to Encaustic novice!! in the Australia Tiling Forum area at TilersForums.com
Plazma cutter causing SPD failure?? Discussion ThreadPlazma cutter causing SPD failure...
A question about mitering and matching epoxy colour I'll be working with some pinkish matt...
  • Sticky
5K
Matthew7
Bedfordshire
Encaustic novice!!
    Votes: 8 5.9%
    Votes: 13 9.6%
    Votes: 8 5.9%
    Votes: 39 28.7%
    Votes: 16 11.8%
    Votes: 34 25.0%
    Votes: 3 2.2%
    Votes: 2 1.5%
    Votes: 20 14.7%
    Votes: 18 13.2%
    Votes: 15 11.0%
    Votes: 7 5.1%
    Votes: 3 2.2%
    Votes: 4 2.9%
