Discuss Encaustic novice!! in the Australia Tiling Forum area at TilersForums.com.
m3fitter
More Tips:
test a single tile with the sealing process, some of the deep colours ( Burgundy, Navy blue ) bleed into the background colour if sealer is applied too roughly, best advice is to test your tile with the whole process, I've found Lithofin products to be the best on these naughty tiles. I would suggest a good Daywork rate or £75.00 a metre minimum, as you will be coming and going with washing, sealing, sealing, waxing, grouting, washing etc.etc ( not in that order ! )
don't forget to cobblewax ( lithofin ) them at the end ( which is a process that these tiles will need twice a year, as traffic wax ! )
Lastly: thoroughly clean your wet cutter, use water very sparingly, just enough to cool the blade
Ps: They're a pain, allow enough time, and then add some more for good measure :)
Reply to Encaustic novice!! in the Australia Tiling Forum area at TilersForums.com
Plazma cutter causing SPD failure?? Discussion ThreadPlazma cutter causing SPD failure...
A question about mitering and matching epoxy colour I'll be working with some pinkish matt...
  • Sticky
5K
Matthew7
Bedfordshire
Encaustic novice!!
    Votes: 8 5.9%
    Votes: 13 9.6%
    Votes: 8 5.9%
    Votes: 39 28.7%
    Votes: 16 11.8%
    Votes: 34 25.0%
    Votes: 3 2.2%
    Votes: 2 1.5%
    Votes: 20 14.7%
    Votes: 18 13.2%
    Votes: 15 11.0%
    Votes: 7 5.1%
    Votes: 3 2.2%
    Votes: 4 2.9%
