Discuss Epoxy grout. Timescale. in the British & UK Tiling Forum area at TilersForums.com.
F
FreeD
Ok I've got to tile a Chinese restaurant for a China man. I may have to epoxy the lot. Never used the stuff before, got to price it up. Apprx 8m2 of tiling. 2mm grout lines, tile size 250 x 330.
I am slow at grouting compared to you guys who grout all the time, how long do you think it will take me to do 8m2 of epoxy including full clean down?
Alan.P
Kerapoxy 3mm groutlines!
That's good gear to use, make sure the tubs are kept warm prior to use as it makes it a lot easier to use, iirc the coverage out of a tub isn't great, but we had 5mm joints, you'll need lots of clean water, a few pads and sponges, it really won't be a bad job, good luck, just use one tub at a time,both apply it and both wash off, you'll have it done in no time, the last job I used it on we had about 50m2 on the ceiling alone, mid June in the heat, ouch, some pictures in my albums under Chiswick house,
N
NZ_Tiler
If you spread to much epoxy and don't wash it off in time, it will go hard on the tile making it near impossible to wash off. It will also go off in the bucket if you mix more then you can spread in a short amount of time. Scales are a good precise way to half the tubs. This way you are working with fresh grout, easier to spread and wash off, and no waste from it going off in the bucket. Use plenty of fresh water with emulsifying pads then a wash with clean sponges. Have fun!:smilewinkgrin:
Alan.P
Hello... becouse if you done this many times it's easy for you , but if some never did apoxy it's -hell
Hello lmao, how old, anyway, I only asked because you said you can't do more than 2m2 at a time, just wondering what your thinking was, it does all depend on experience, confidence etc but anyone and I do mean anyone should be able to do a tub at a time.
Reply to Epoxy grout. Timescale. in the British & UK Tiling Forum area at TilersForums.com
Hello, I did some reading here and there, but the opinions seem to diverge at some point and I...
Hello, after watching so many instructional videos and planing, I just can't understand how to...
Hi there I’m new to Tile Forum and joined to get professional opinions because I really need...
Hi, I have had both polished and matt textured wood effect tiles laid in my house and am having...
7K
    Votes: 14 9.4%
    Votes: 44 29.5%
    Votes: 17 11.4%
    Votes: 35 23.5%
    Votes: 21 14.1%
    Votes: 18 12.1%
    Votes: 16 10.7%
