Everbuild SBR Bond as primer
Yes, dilute it 1 part sbr :3 parts water and apply to the concrete with a brush or roller. You want it thin enough that it soaks in and doesn't sit on top and skin over. Let it dry and then tile away.
Clean any grease etc from the surface before applying.
Thanks Steve, I'll do just that:thumbsup:
Hey, tiling a painted wall in my living room. I’ve scrapped the paint off the best I can and scratched some lines into it before I prime it with SBR. Do I dilute the SBR before I prime the wall?
:yikes:
Never did tiling before, just having a go mate.
Gave the bitumen a good neat coat of Bal SBR Bond, still a bit tacky, also were no bitumen on concrete also still tacky almost two days later, almost dry.
If I was to give Floor Vinyl Tiles, Concrete, Old Bitumen adhesive left over from removing tiles,two coats of SBR neat will it take the floor Tiles better.
Thanks Mate.
Really you need to get all paint off the walls for a job that any of us could even begin to say might last !unless you sticking paper Tiles to the primed paint surface . I know it's alot of work but some plaster or boards are not strong enough to hold certain weights of tiles !paint is never strong enough
    Votes: 9 5.2%
    Votes: 17 9.9%
    Votes: 12 7.0%
    Votes: 49 28.5%
    Votes: 21 12.2%
    Votes: 40 23.3%
    Votes: 4 2.3%
    Votes: 5 2.9%
    Votes: 24 14.0%
    Votes: 19 11.0%
    Votes: 17 9.9%
    Votes: 8 4.7%
    Votes: 5 2.9%
