Discuss External balcony waterproofing and tiling in the Australia Tiling Forum area at TilersForums.com.
mike111
Hi everyone
I have two external balconys that need refurbishment as leaking,
The maintenance guy on site / block of flats , seems to think the construction of the balconys is as,
1 reinforced concrete construction
2 bitumen/asphalt waterproofing
3 quarry tiles finish
4 5mtr x 2 Mtr
5 drain 300mm in from one corner
There is a good gradient , but he is not sure if this was a screed under the asphalt or on top.
You all know the score regarding asphalt/bitumen and tile adhesive gaurantee.
schluter have said that they do not have a total system for this application I.e waterproofing and uncoupling membrane.
Mapei I did use a couple of years ago on a balcony on the same flats , aqua seal I think, on top of old tiles but there was no substrate movement and worked fine , but I don't think I will use for this situation as a lot of substrate movement.
I have two questions
1 what is the best construction to take it all back to the reinforced concrete ?
2 What is the best way to proceed if I can remove quarry tiles and leave the asphalt inplace , with then just repairing /resealing the asphalt.
any help would be great Mike.
mike111
I've just done a terrace with a flexible polyester resin waterproofing membrane, 25 year guarantee!. I'm in Spain but I'm sure there's similar products in the UK.
What was the product name , I had thought of this but not used one before , but I will look into this, but sounds good, thanks Mike
Mike, my experience here in the States is if you can properly fix or patch the asphalt waterproofing, then use a cleavage membrane over the asphalt and under a 2x2 inch wire reinforced mud bed(4-5 parts sand to 1 part cement) that is properly pitched a 1/4 inch per foot to the drain or away from the structure. I am not a fan of asphalt waterproofing, so if you can get back to the concrete and use a complete system from Mapei, that would be the way to go.
Reply to External balcony waterproofing and tiling in the Australia Tiling Forum area at TilersForums.com
Work Done Epoxy grout was installed by the Grouting company on the tiles on the external balcony...
    • Friendly
Moved this as I incorrectly posted in the Pro forum! Hi all, Finally getting to lay the tiles in...
    Votes: 9 6.2%
    Votes: 13 8.9%
    Votes: 11 7.5%
    Votes: 44 30.1%
    Votes: 17 11.6%
    Votes: 34 23.3%
    Votes: 3 2.1%
    Votes: 20 13.7%
    Votes: 18 12.3%
    Votes: 15 10.3%
    Votes: 7 4.8%
    Votes: 3 2.1%
