Discuss external corners in the British & UK Tiling Forum area at TilersForums.com.
Tilestiles
As stated in previous threads, setting out can be the making or breaking of a good job so take your time doing this and you will reap the benfits as the job will look right at the end. Cant stress how important good setting out is for the overall finished appearance of the job!!
External corners should be beaded and are normally finished with tile trim. Providing cuts are nice and straight, tile trim and grout finishes them off fine. If wall isnt plumb, then measure widest gap and cut all tiles same width to square things back up. Then edge with correct size trim. Build up tiles on adjoining wall for a nice neat square finish. (Hope that makes sense!!)
Where are you Connors?? Am I correct in thinking you are from warrington??
grumpygrouter
yes i did the pts course in warrington. course was very helpfull. but at the end of it you are starting the learning curve.. it is just the basics really and the rest is all crammed in. i could do with going out on the job with someone for a bit of hands on knowledge really
Did you do 2 or 4 weeks?
Grumpy
E
enduro
Just keep asking questions we are all here to help, it does take time but you will get there in the end, it takes a year or so to build up speed. I have been tiling a couple of years now, i don't advertise just work for a few builders, architects and plumbers. I had five bathroom jobs today from one plumber for next month. Just take your time setting out, and make sure your attention to detail is very good. Im not the fastest tiler i just make sure my job is 100% first class.
grumpygrouter
how are you doing now grumpy????? are you confident on any job. and how did you go about having the confidence to take on buggered walls... is packing out ok and all about having the bottle to try it
Still learning like almost everyone else on here, but I just go and have a look at the job, take my time and hopefully make a good judgement of what is required. I have learned a huge amount from the forums. I am confident in my knowledge of what is required but that is not the same as actually doing it. Hand skills are different to knowledge. These get better the more you do and at the same time you can refine your knowledge in relation to the job you are doing or have just finished.
Uneven surfaces are the hardest thing I find to get to grips with. The first thing I really look at in detail when I am pricing a job now is condition of the surface. It is soooooo important. If it is not good before you start, you have to make it a suitable as you can. Makes the actual tiling that much easier.
You can only "pack out" so much! If you need to put 10mm of tub addy on the wall, it will crack when it is drying so you need to straighten the wall first by what ever method you find most suitable. Skimming with rapid set is usually sufficient.
Grumpy
Reply to external corners in the British & UK Tiling Forum area at TilersForums.com
    • Friendly
    • Useful
Hi, Im looking for a recommendation for a liquid tanking. I have to use a liquid tanking...
There's a video on youtube of a guy templating for large format floor tiles, and I get the...
external corners
    Votes: 14 9.4%
    Votes: 44 29.5%
    Votes: 17 11.4%
    Votes: 35 23.5%
    Votes: 21 14.1%
    Votes: 18 12.1%
    Votes: 16 10.7%
