Discuss external grout paint? in the British & UK Tiling Forum area at TilersForums.com.
DHTiling
Aqua mix grout colourant is fine for outside use..
Aqua Mix Grout Colourants (Re-colour existing grouting)
DESCRIPTION:
Aqua-mix Grout Colourant is an easy-to-use waterborne epoxy that re-colours, seals and rejuvenates existing grout joints. Also simplifies ongoing grout cleaning.
USES:
Sanded, un-sanded and epoxy grout joints. Effective for interior and exterior applications.
TEST A SMALL AREA:
According to application instructions, with a minimum 1-hour cure time to determine desired results.
EXPECTED WEAR UP TO 15 YEARS:
Will vary depending on hardness and texture of surface, type of area, surface wear, frequency, and type of maintenance products used. Weather conditions, harsh cleaning methods and high-alkaline, acidic or solvent-based cleaners will affect wear.
COVERAGE:
Approximately 5 m2 to 60 m2 237 ml bottle depending on width and porosity of grout joint, size of tile, and method of application.
For example: On a 30 x 30 cm tile with a 3mm joint a 237 ml bottle could cover 30 m2 per 2 coat application
And available from trade tiler.. TradeTiler.Ltd Grout Colorant
aqua blue
Aqua Mix products are the most trusted source worldwide for all tile and stone maintenance needs. Offering sealers, cleaners, grout colorants, problem solving and stone restoration products, Aqua Mix products provide professional performance and unsurpassed innovation and customer support.
http://www.custombuildingproducts.c...ation/leedcertification.aspx?user=pro&lang=en
Aqua Mix products are the winner of NTCA / Clear Seas Research award for Most Preferred Brand of Sealers and Cleaners. :thumbsup:
Reply to external grout paint? in the British & UK Tiling Forum area at TilersForums.com
Hi, Need to choose a grout for the above. For the black floor tiles 300x600 am thinking either...
Hi, can anyone advise me on how to prep a painted brick or block wall for tiling? Do I just wash...
Had new bathroom by a builder who has subsequently gone bust and after 6 months the floor has...
Hi I have just had my wet room tiled and after one use the cream coloured grout has gone black...
    Votes: 14 9.3%
    Votes: 11 7.3%
    Votes: 44 29.1%
    Votes: 18 11.9%
    Votes: 36 23.8%
    Votes: 21 13.9%
    Votes: 18 11.9%
    Votes: 16 10.6%
    Votes: 7 4.6%
    Votes: 4 2.6%
