Hello all, I have a job coming up to install 20mm thick porcelain large format tiles onto a freshly laid concrete slab (once cured)
Looking for some advice on the following....
1. How long from the day the concrete is poured until you can tile ?
2. I've done this many times in Australia but as climate and weather is a lot different here I can only assume the prep work must be too.... what's the method for sealing the slab?
As in what primer/waterproofing agent do people use in England than coinsides with the English climate?
3. Any other advice anyone's willing to add would be very much appreciated.
Thanks in advance
Thanks in advance
