Guest viewing is limited
Discuss Externals corners on retro beveled edge tiles in the Canada Tile Advice area at TilersForums.com.
charlie1
Hi Ian, your options are:
trim that matches the thickest point.
or
mitre the edge of tile (tricky)
if you go down the mitring route then ensuring walls are plumb is good practice but is a must IMO when doing an external corner, If you use trim then grouting will play a part in the finish, avoid being tempted in to thinking "that will be ok when grouted syndrome", it may looks acceptable at first if its hiding rough cuts but remember, grout depreciates in time so pay close attention to your external cuts both when cutting and when grouting.
Anyway, just realised you asked a specific question relating to trim, my preference is genesis square edge but for your tile and situation I'd be tempted to source a corner tile in keeping with the retro look of the metro tile.
I'm currently having lunch and had a snickers.... Maybe that advert is true lol... Good luck
AliGage
Subscribed
4,531
1,188
Peterborough, England
In my opinion i think trim looks awful with these. If you mitre them they look so much better. I did a Victorian bathroom last year. As long as on the corners you use a full tile around the corners and if its a but tile use a cut tile around the corner. The natural bevel of the tile around the corner will look perfect if you do it that way.
Reply to Externals corners on retro beveled edge tiles in the Canada Tile Advice area at TilersForums.com
Hello, after watching so many instructional videos and planing, I just can't understand how to...
Hi, 1200 wide tray and tiling shower enclosure recess with metro tiles where the 1200 wide...
Been advised to move this post to the uk forum, didn’t realise it was in the USA forum Would...
    Votes: 14 9.4%
    Votes: 44 29.5%
    Votes: 17 11.4%
    Votes: 35 23.5%
    Votes: 21 14.1%
    Votes: 18 12.1%
    Votes: 16 10.7%
