Time to get nasty....
How did you get on with this Meg? Any update from the tiler?He will not admit that it’s not acceptable. He’s blaming the adhesive, the fact that the plasterboard was uneven ( he replaced all the boards)
He got very upset and said I was calling him a cowboy. He left without repairing it and said he won’t be fixing it in the next two weeks. I’ve paid him £3500 of the £4540 he invoiced.
He did my neighbours bathroom and had to come back because a floor tile cracked. He’s working for another 2 people in our close at the moment. He’s bad mouthing me to them saying I’m just causing trouble. I’ve decided I will just get another tiler to redo the floor and window. Thanks for your input
There is an argument to be had in saying that if you dot enough, then dab a lot, you might get the coverage percentage right and hold on.Hi
Firstly, before I get abused I would like to agree with all of the comments above. It has not been done correctly and it is very unlikey that there is a fault with the adhesive. If you can find out the manufacturer of the adhesive I am sure that a sample can be tested to see if it is at fault (I know this can be done with plaster, never needed to try it with tile adhesive). If they can confirm the adhesive is not at fault it will work in favour if you intend to pursue it.
Here is the unpopular bit, having looked closely at the picture I suspect the reason it has failed is down to dust on the back of the tile causing it not to bond and not the fact that it has been dabbed. I think you can see the white dust stuck in the adhesive.
The fact that it has been dot and dabbed does not necessarily mean the rest of it will fail (although no one can guarantee that). I have taken many many tiles up over the years thats have been dot and dabbed and they showed no sign of failing. The only way those tiles were coming off was with a hammer and chisel.
Good luck getting it resolved.
