GMJ
I am about to tile our downstairs toilet floor with my left over 10mm thick quartz en suite tiles. This toilet waste pipe is directed into the floor. to the best of my knowledge you can not get a hole cutter that will cut a 120mm hole which is what I would need. What is the best way of cutting a large hole (or 2 semi circles as will be in 2 tiles). I have a wet tile cutter but obviously this only does straight cuts and most of the standard files and nippers. I did once try to file one of these and seemed to make little headway. Any suggestions would be greatly appreciated.
