Hi All
I have started removing some of the old tiles from my kitchen walls ready for the refurb project that I'm starting in a couple of weeks. As I'm removing the tiles I'm finding that some of the skim coat of plaster is blown and so any that hasn't fallen off will have to be removed. I've read loads of great advice on here about what to do but have a few questions about which option I should choose and I would also like some help identifying the backing plaster / render.
Boarding isn't an option as space to fit the cabinets in is tight as it is and the substrate under the skim coat seems very hard so I don't fancy trying to remove it.
I have added a picture of where a patch of skim coat has come off, the stuff underneath is very hard and doesn't scratch easily with a screwdriver, it also seems very solid and doesn't seem to be going anywhere. When I had to chase a wall out in another room I ended up having to use an angle grinder as my bolster just bounced off.
I'm guessing this could be sand and cement render (the house is early 60's), if so is my best option to remove all the lose plaster, prime the wall and patch up he holes with some rapid set adhesive?
The tiles I'm using are 100 x 300 8mm thick ceramic.
Thanks in advance
Dave
Thanks in advance
Dave
