F
Flintstone
What's your method? I have always cut tight to the ceiling and grouted. I've seen a few pics where it looks like some have siliconed to ceiling, who does that?
if ceiling is already painted I silicon if not decorators cork.
sometimes, but normally just a wet fingerDo you use the profile tool with caulk?
Harsh that! I worked on a site of 300+ houses when I was 17 or so. Painters were ar#ehol#s, kept painting all the walls in the bathroom knowing full well we were tiling the wet areas. After weeks of arguments I began to write co#k in primer on the living room walls. Completely invisible until they started to emulsion. Took about 12 houses but they soon got the idea.I Silicon to the ceiling if I don't like the customer!
(and smear too!)
looks fine......I bet white caulk looks good against black tiles and grey grout
I mask a tape line around walls 3mm down from ceiling and it always gives a perfect straight line around ceiling, looks far better than a joint filled with groutIle give the caulk a go on the next one
