Fireplace advice
Been asked to do a fireplace with porcelain tiles, these tiles will go right back under the chimney area, and will have a working fire basket on it. Just wondering if this was ok, and if so would i be alright using keraquick and ultracolour plus grout. Any advice will be appreciated.
That Adhesive and Grout should be fine. I would be worried about using a glazed product though (Assuming it is a glazed porcelain you are talking about)
bearing in mind they'll have been fired at about 1200 dgs centigrade, I think they should be ok
Be very careful! … The dimensions of your hearth are covered by law under Part J of the building regs. This basically tells you the dimensions of your hearth from your appliance to any combustible materials (ie skirting boards and carpet.) Plus the definition of the edges. A HETAS registered engineer could turn up and make you / the owner rip your hearth out if its not to spec. Its explained really clearly in Part J which you can get from here …. http://www.planningportal.gov.uk/uploads/br/BR_PDF_ADJ_2002.pdf
speak to a local solid fuel / stoves retailer ref if you need to use fire cement, you'd have to explain to them your appliance / fire dogs / fire basket etc. what is the material under the hearth? (wood / concrete ?) you defo need to know - read Part J thoroughly before taking the job. IMHO if its wood under then I'd fit stone slab to be safe (I can post a picture to explain if required)
I have had customers that have had glazed porcelain crack when a hot coal has dropped on them. Just speaking from experience. Which I am sure you have much more of than me :lol:
Just had a quick look through this stan, and it seems to be about gas appliances, not real fires,but i will check with a local shop that supplies real fires and wood burners ect.
