Discuss First fit the toilet then tile or vice versa. in the UK Tiling Forum area at TilersForums.com.
Time's Ran Out
Do your 1st fix plumbing and get the toilet pan and cistern in place for the soil outlet and cold water inlet.
Make sure if you are tiling the floor you adjust the height position of the pan/soil for the additional height required.
I always tile without the toilet in place and have it fitted after. Then if it's changed you will not be searching for matching tiles 5 years down the line.
If it is a Stone floor make sure it's protected when the pan goes back into place as this is when scratches occur.
Dan
Admin
Staff member
5,096
1,323
Staffordshire, UK
As above. :)
No point cutting around it if you can avoid it. You'd only need to do that if you were re-tiling an existing bathroom floor and only then if you can't lift the loo somewhat to fit tiles under. Looks better too. Small beed of Silicon around the base keeps it from working the screws out in the future (if you're using screws - we used to just Silicon them in and cut the screw heads off and Silicon those in the holes where they'd normally go).
John Benton
1,138
Leeds
On the other hand, if the toilet and sink are fitted first then you conveniently have somewhere to go to the toilet (and wash your hands) while tiling! :lol:
If you do go with Swedish Mike option then bear in mind that the pan and pedestal generally have a tapered moulding i.e. wider at the bottom and narrowing the higher you go, so a straight cut on the tile will mean a wider gap than you probably require. Mike knows of a special tool that can cut angles on tile edges, don't you Mike. :smilewinkgrin:
Mike Mike
[video=youtube;f0TAxLjkdFU]http://www.youtube.com/watch?v=f0TAxLjkdFU[/video]
"OH NO YOU DIDN'T" just bring up the.....MITRE WIZ!! :lol:
Mike Mike
And what about tiling behind bath. Should I run full tile behind bath? Or should I cut it with high of bath?
Cut the tiles a good 2 - 3 inches above the bath. That way lots of water can get down the side of the bath. Make sure you have not tiled underneath the bath either, othewise the water will be unable to find its way down onto your kitchen ceiling.
Reply to First fit the toilet then tile or vice versa. in the UK Tiling Forum area at TilersForums.com
Hi. We've had a bathroom installed with electric mat underfloor heating in a new extension. The...
Hi, 1200 wide tray and tiling shower enclosure recess with metro tiles where the 1200 wide...
Hi, can anyone advise me on how to prep a painted brick or block wall for tiling? Do I just wash...
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
