Discuss first mosaics in the British & UK Tiling Forum area at TilersForums.com.
groucho
Hi all, first mosaic job on wed coming up. I have put up mosaics borders start at one end & fiddle it around to finish on full tile. Is it the same on the full sheets or do you still perform the normal set up. Start from the worktop, if so do you sit the tiles on on the worktop or do you have 2mm spacers on each tile?? Do you put them up in brick fashion to hide the lines of the sheet?? I have a Montolit tile cutter which Ive heard is brill for cutting mosaics. Pull the feet down and you can cut each tile.Grout float to fix them to the wall, dont play around with them too much the backing gets wet.Is there anything else I should know ????? Not full of confidence when you have not done something before but Im sure when its done it will be another job under my belt. tile size 5 x 5.
GazLC81
I'm part way through my first ever mosaic job at the moment. What a pain in the ar*e! Must admit it looks the part once it's on the wall.
I have started on the worktop but have had to cut the tiles where they meet the cupboards and to the window ledge, around the window too. No matter where I started this would have been to case.
I have a rubi ts50+. I have scored with this and then used tile cutters to break the pieces off.(takes too long this way really!) It has been mostly successful doing it this way. Just score your line a few times.
Would have used a wet cutter but the tiles on on a paper backing so would just all fall off if they got wet.
I will definitely quote more next time I get a mosaic job
Let us know how it goes
Gaz.
Reply to first mosaics in the British & UK Tiling Forum area at TilersForums.com
Hi, 1200 wide tray and tiling shower enclosure recess with metro tiles where the 1200 wide...
There's a video on youtube of a guy templating for large format floor tiles, and I get the...
Hello, I’ve put up mosaic tiles and some of them (the shiny metal ones) have a protective film...
first mosaics
    Votes: 9 5.4%
    Votes: 17 10.2%
    Votes: 12 7.2%
    Votes: 47 28.3%
    Votes: 21 12.7%
    Votes: 39 23.5%
    Votes: 4 2.4%
    Votes: 4 2.4%
    Votes: 22 13.3%
    Votes: 19 11.4%
    Votes: 17 10.2%
    Votes: 8 4.8%
    Votes: 5 3.0%
