mache
hi bud, I wouldn't of commented without knowledge. I will deffinately try to find out what system has been used. all i know is an impey system has been used throughout all of the building sites i currently am working on and it has not gone well, 12 months down the line they are all failing and it is not down to installation. and very recently a wetroom repair that had previously been repaired they tried to strengthen underneath the tray for a second time and once my big backside stood on top was bouncing (i could even see it moving let alone the guy with his eye against the ground)... its costing thousands per property as it is all mosaic stone too!
Don't get me wrong, not doubting what you found, but would be interested to hear more about what was installed if you can find out. e.g. if the trays were the older flat bottom or the matrix ribbed versions. Membrane identification should be fairly easy as it will be the bitumen based tilesafe or the waterguard co polymer. Any word on site with regard response from Impey on reason for failure? sounds like a site of this size the first port of call would be to get the manufacturers in for investigation. Please do post what information you find as I am interested.
