Discuss First Timer Metro Tiles On Wonky Walls in the Canada Tile Advice area at TilersForums.com.
morganste
Good afternoon!
Hopefully someone here can point me in the right direction.
I'm about to start tiling in between my worktops and wall cabinets in the kitchen. The problem is the walls are all over the place!
My thinking was to true the walls with plasterboard and tile over that, would this be a proper method?
The problem is I would want a trim that would go over the plasterboard and tile at the end on the worktop run (from worktop to wall cabinet) which would be roughly 15mm thick without adhesives.
Can anyone advise whether I'm going about this the right way please?
Kind regards,
Steve
morganste
It's hard to put into pictures but you should see what I mean with these...
I'm also hoping the new tiles will cover the gap between the worktop and the wall
Martino
I would board the 14mm wall with 12.5mm plasterboard...as for the other wall you could probably get away with spreading the wall and also spreading/back buttering the tiles to get more depth too....bear in mind you may need a deeper tile trim if you build the tiles out.....your also more than likley to nee longer screws for any electric sockets you have too
Reply to First Timer Metro Tiles On Wonky Walls in the Canada Tile Advice area at TilersForums.com
Hi, 1200 wide tray and tiling shower enclosure recess with metro tiles where the 1200 wide...
Hi, Need to choose a grout for the above. For the black floor tiles 300x600 am thinking either...
    Votes: 9 6.3%
    Votes: 13 9.0%
    Votes: 9 6.3%
    Votes: 44 30.6%
    Votes: 17 11.8%
    Votes: 34 23.6%
    Votes: 3 2.1%
    Votes: 20 13.9%
    Votes: 18 12.5%
    Votes: 15 10.4%
    Votes: 7 4.9%
    Votes: 3 2.1%
    Votes: 4 2.8%
