Guest viewing is limited
Discuss Fitting a tile edge in the UK Tiling Forum area at TilersForums.com.
Guru86
Hello,
I am about reayd to tile and have bought a white plastic tile edge to go on the ends of tile were it meets painted wall and round windows. How are these fitted?
Do I just stick them to the wall with the adhesive and then tile over them again using adhesive?
If so do I stick the edge to the wall first and wait for this to dry before tilling the rest of wall??
paulyoung666
i tend to stick them to the wall while tiling,after spreading the wall i put my trims in place about a few mm away from where the tile will be then slide them in as i tile up to them so thay are tight to the tile:thumbsup:
so you dont leave room for grout then ??? , just curious , i have been using square edge metal trim today and left room for grout between tile and trim :)
Sean fsy
again another subject where folk have their own ways of doing things, me personally i tile right round the window first and leave the trim and window reveal to the end. usually cut the bottom plastic first with a 32tpi hacksaw and small mitre block. always cut short(very minimal maybe 1mm) this will allow the vertical trim to sit into the mitre perfectly and not sit above it which doesnt look right sometimes. i then proceed to do the sides then lastly i do the top reveal and leave the trim sever so slightly long so its a nice tight fit(ok for plastic trim but obviously not for metal trims) most trims you will find are designed for the tile to sit into the trim, some have a little strip in them which can be removed dependeing on the depth of the tile. i sometimes also use toughened pointed staples to fix the trim into plaster etc just to stop them moving. i always say to myself never start to tile round a window if you dont intend to finish it straight away. like i say we all do things differently and do things that suit ourselves. i always tend to tile around a window in the morning so you can keep an eye on it over the day rather than leaving it overnight when you cant check it. some times cut a couple of pieces of wood to 'chock up' the tiles just for added safety.
Peter
Depends where the trim is running I suppose. If it's running vertically from floor to ceiling, I'd put the trim on first and then tile to it, but if I'm doing half height walls, I'd stick the tile on then squeeze the trim down into it. Window reveals, I'd tend to cut all reveals to ensure a good fit before tiling.
doug boardley
same as for me Sean:thumbsup:
Aston
if you do it sean and dougs way which i do a lot of the time, sometimes you have to leave one side row of tiles out because it can sometimes be difficult to push the last piece of trim in, when all 4 sides are tiled...so in effect i would tiling the bottom, left hand side and top but i'd leave the right hand side tiles off, bed the remaining piece of trim then fix the tiles to that side..
Dan
Admin
Staff member
5,094
1,323
Staffordshire, UK
Some of the threads in the tiling forum that have had a lot of views are being bumped up into current discussion. Just walk on by if it's not your flavour right now. Perhaps it'll help somebody out one day, and they become members, and then they post a thread, and professional tilers respond, and then you learn something from them...? Maybe?
Reply to Fitting a tile edge in the UK Tiling Forum area at TilersForums.com
There's a video on youtube of a guy templating for large format floor tiles, and I get the...
Hello, after watching so many instructional videos and planing, I just can't understand how to...
Fitting a tile edge
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
